VeriStand
using usb stick in veristand
Steve thank you very much .
It work pretty well.
I have created a procedure where i will define the some delay and write the "1" to log command variable
Message 11 of 12
(2,801 Views)
I have created a procedure as shown in the attached file for generating a TDMS file for every 20 seconds(using Embedded Data logger Custom device). But the new file is created at every 40 seconds instead of 20 seconds. I have set the dwell for 20 seconds after the log command is set to 1. Whatever the dwell value is been set, the new tdms file will be created at double the dwell time. I dont understand where i have done the mistake. The fifo size is been set to 50 and decimation is set to 100, since i want log the data at 1 hz . Please reply asap
Message 12 of 12
(2,783 Views)
