VeriStand
veristand
Is it possible to get the veristand system definition errors and warnings through the .Net API ?
Message 1 of 9
(7,940 Views)
Hello matcy,
After doing some researches, I found the information that regarding the VeriStand System Definition API, Error reporting is terrible for now. Some improvements are planned but I can't tell you exactly when.
Currently several methods in the system definition API can fail, but the information available to the user consists of a pass/fail. Currently, when a failure occurs, there is no indication why the failure occurred.
I found you a simple System Definition API that you can download and take a look at it :
VeriStand Simple System Definition API : https://decibel.ni.com/content/docs/DOC-26812
The following tree shows the navigational hierarchy of the NI VeriStand System Definition API : http://zone.ni.com/reference/en-XX/help/372846F-01/vsnetapis/api_hierarchy/
Jérémy C.
NI France
Message 2 of 9
(7,915 Views)
Hello JeremyC,
thanks for your reply.
What I would like to do is, from C# langage, call the veristand system definition .NET API in order to check a system definition file
in the same way as the system explorer does when you click on the Error / Warning icon , and get the results in my application.
Which classes/methods should I call to do that ?
Message 3 of 9
(7,909 Views)
Hello again,
Depending on the VeriStand version that you use, you'll find the System Definition API help to a location similar to this one :
C:\Program Files (x86)\National Instruments\VeriStand 2011\Help
You should find a "veristandsdapi.chm" file which contains Methods/Properties that you want.
Jérémy C.
NI France
Message 4 of 9
(7,902 Views)
JeremyC,
I have searched for this information in the veristandsdapi.chm, but didn't find anything in the 2011 nor the 2012 version.
For RealTimeSequence, there is a compiler class which returns CompilationEvents.
The StimulusProfile class has a method CheckForErrors(), which also returns CompilationEvents
But I didn't find an equivalent method for system definition, although the system explorer does the job.
Message 5 of 9
(7,894 Views)
As I wrote it in my first answer, except the following method, I don't think there are other error mechanisms fror now :
SaveSystemDefinitionFile Method (String)
Jérémy C.
NI France
Message 6 of 9
(7,881 Views)
hello,
i've somme problems with my ni veristand
so i have three models and i have to import theme into veristand to develop my interface but one of the models is an AMSEIM LMS model
my question is how can i importe an .ame or amesim model in veristand
please i need your help
Nacim. OULD-OUALI
Message 7 of 9
(7,866 Views)
plz answer me you just visit the question
give me some advice or help i'm waitting
Nacim. OULD-OUALI
Message 8 of 9
(7,845 Views)
Hello chauvesouris,
You posted a new question. You need to create a new post if you wish to be helped.
Jérémy C.
NI France
Message 9 of 9
(7,837 Views)
