VeriStand
veristand
1、I want to use veristrand to calibrate a model  output channel ,and the software reports an error -307768
2、Is the calibration in veristrand linear?
3、How to understand the coefficients in calibration function ?
(2,369 Views)
Hello:
1. After deploying veristrand, run LabVIEW to write a calibration value for the model output channel and report an error;
2. How to understand the coefficients in calibration function
(2,372 Views)
Can you provide the description of that error?
Additionally, please attach the code. It will be easier to investigate the problem.
(2,324 Views)
Hello:
     I have a problem. I have a PT100 thermocouple board. The model output interface is bound to the thermocouple board channel. The model output value is in temperature and the thermocouple is in ohm. The conversion between these two units is not linear. I want to calibrate these channels through veristrand calibration function. Do you have any solution?
    I wrote a conversion function and put it in the attachment. You can see how this function is integrated into veristrand calibration file to achieve the purpose of calibration model channel。
(2,286 Views)
