VeriStand
working directory
I have some issues when loading NI Veristand model (dll) in office mode...
My dll depends on some other dll which is loaded during runtime. To successfully run the model, main dll needs to be able to find its dependency.
To achive this, I need to set Veristand working directory to the folder where dlls are (there are both in the same folder).
Can I somehow change Veristands current working directory? Currenty, it is set to be my Desktop folder. This is not what I want since dll also generates results in working directory and I don't want it to be Destkop.
Is this possible?
(5,056 Views)
Are you running the model on windows or an RT target?
Jarrod S.
(5,028 Views)
This is relevant for Windows only, not RTPC
(5,013 Views)
Hello ipavl,
I'm not sure if this answers your question, but if you navigate to Tools>>Options>>Search Paths and add your .dll path to that section, does this resolve the behavior you are observing in NI VeriStand?
If it does not, could you clarify the issue that you are experiencing? Perhaps screenshots would help here.
I hope this helps!
Nadine H.
(5,000 Views)
