VeriStand
workspace objects channel info
Wow that is way old (2009) and uses a LabVIEW tree control instead of the wonderful NI VeriStand channel selection dialog .NET control. I don't recommend using this.
if you have access to the integrator training community t
ill try to get this devzone updated next weekhere is a much better VI that serves the same function. If not there is an example tool installed into the labview\examples\ni veristand\ directory that shows the .NET control.
Stephen B
Message 11 of 15
(3,099 Views)
My reply got garbled. Try #2:
if you have access to the integrator training community there is a much better VI that serves the same function. If not there is an example tool installed into the labview\examples\ni veristand\ directory that shows the .NET control.
Stephen B
Message 12 of 15
(3,094 Views)
OK I've updated that devzone with a much better example
Stephen B
Message 13 of 15
(3,068 Views)
How do I get to the updated devzone?
Message 14 of 15
(3,053 Views)
http://zone.ni.com/devzone/cda/epd/p/id/6266
Stephen B
Message 15 of 15
(3,041 Views)
