Version Conversion
I want to change my LabVIEW application from the version 2018 to 2016
I want to change the application version from 2018 to 2016 thanks.
(509 Views)
If it is a built standalone application, you cannot change it. You need to down-convert the project (save for previous) in LabVIEW 2018, the re-build it in LabVIEW 2016.
If I did not correctly understood your problem, please be much more specific.
(486 Views)
