Version Conversion
Need help converting LabVIEW 2026 VIs to LabVIEW 2020
Hi everyone,
I created some VIs using LabVIEW 2026, but I currently only have LabVIEW 2020 installed on my machine. Could someone please convert my attached VI(s) to LabVIEW 2020 version?
Thanks in advance for your help!
(343 Views)
Accepted by topic author Sondos510
Here you go.
I also included a .lvversion file (the reason I used a zip file). If you keep that with your VI, then LabVIEW 2025 and newer will keep the VI saved in 2020 format.
(294 Views)
