Version Conversion
Please help me convert these files from LabView 6.1 to LabView 2023
My source LabVIEW version: LabView 6.1; and 2) target LabVIEW Version: 2023
These files initially run in Win XP. I want these files to run in Win 11.
(970 Views)
LabVIEW 2023 can open VIs from LabVIEW 6.1.  There are likely a lot of changes over that time span that you will need to find and correct.  But all of that is outside the scope of this board.
The first thing you should do is create a project and import the code into the project.  It will become easier to manage the code from there.
(952 Views)
Thanks a lot.
(932 Views)
