VirtualBench
Announcing free firmware update - version 1.2 adds Monitor Mode
VirtualBench 1.2 is now available as a free firmware update. New additions include:
iOS application
  • Added Monitor Mode: watch instruments automated in LabVIEW or C.
  • Added firmware update: update the firmware through the iPad app without the need to connect via USB.
  • Added 20 MHz bandwidth filter setting to MSO analog channels.
  • Added Russian support.
Download: https://itunes.apple.com/us/app/virtualbench/id896797834
Windows application
  • Added cursors for decoded buses.
  • Added light theme.
You can upgrade now from the Windows application by choosing Search for Firmware Update from the File menu, or by downloading the installer from http://www.ni.com/download/virtualbench-driver-1.2/5388/en/
Device API
  • Fixed the function generator API to now return an error, rather than a warning, when you specify a combination of amplitude and offset that results in exceeding the +/- 12 V output range (ID 516309).
Screenshots
Monitor Mode on iOS -- LabVIEW sweeps the FGen frequency
Monitor Mode on iOS
Firmware Update on iOS
Monitor Mode and Light Theme on Windows
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 1 of 1
(5,539 Views)
