VirtualBench
Ask to connct the External Trigger (TRIG) to the Function Generator (FGEN)
Ask to connct the External Trigger (TRIG) to the  Function Generator (FGEN).
like to control of the start the function using the External Trigger, how i can do it ?
(5,113 Views)
The trig connector can be used to output the MSO Trigger or the FGEN Start signals, or it can be used as an input for triggering the MSO. It cannot be used to start the FGEN.
(5,093 Views)
tamar2010,
The VirtualBench Function Generator does not support generation triggering.  You can export a trigger with the Function Generator, but you you cannot import a trigger and start generation from it.  Please refer to page 6 of the spec doc for more information:
https://www.ni.com/docs/en-US/bundle/vb-8012-specs/resource/371527e.pdf
(5,092 Views)
