VirtualBench
Bench Program update
I have a question. Can you add the following function: I would like to be able to move digital channels on an oscilloscope in the same way as it is done on other brands' oscilloscopes. Now all digital channels are located only at the top of the window and can only be swapped with each other. I would like to be able to group digital and analog channels. For this, it would be nice if digital channels could be freely moved around the entire window.
It would also be nice to improve the Hands-Free Smart Capture feature. I know for sure that the trigger should work, for example 10 times, and I would like the oscillograph to save the oscillogram immediately with each triggering of the trigger. That is, after the experiment, I have 10 oscillograms left. However, I have no way to wait 500ms at least for the signal to stabilize. For example, I measure signals at high frequencies.
(3,468 Views)
Hi Ioann.
Could you please show a screenshot or the image of the desired configuration of the windows?
You have advanced options over VirtualBench in Labview:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x15jCAA&l=ru-AM
With this it might be easier to obtain what you wish.
(3,258 Views)
