VirtualBench
Can I get analog waveform from VirtualBench?
Hi.
I program Virtualbench from LabVIEW and measure data.
There is a question about a measurement in virtualbench.
(1) Is continuous sample possible in virtualbench?
(2) In the case of impossibility, is there the information about deadtime?
An example: How many seconds is the dead time in case of 20MS?
(3) Is there the product which can measure data of 20MS without deadtime?
I wanted to use FPGA of cRIO, but there was not a module of 20MS. PXI is impossible in terms of budget.
Best Regards,
yh
(7,074 Views)
@gogomac wrote:
Hi.
Best Regards,
yh
1) No, VirtualBench is intended for the benchtop scope use-case where you typically define a trigger condition and want to inspect the data around that point.
2) It depends a lot on your connection (USB or WiFi), acquisition size, and more.  As a rough example, though, on USB with a 20ms acquisition, I was seeing a dead time of about 30ms.  An acquisition size of 1ms had a dead time of about 4ms.
3) When I think of continuous acquisitions, I typically think of DAQ products.  I don't know of any DAQ products that go that fast, though.  They typically go up to 1-2MS/s.  Why do you need 20MS?  Do you need 20MHz of bandwidth or acquisition speed?
Zach Hindes
NI R&D
(7,060 Views)
You might also consider the USB-5132 and USB-5133. However, you will likely need PXI or PCI to reliably get the throughput to acquire continuously at 20MS/s.
http://digital.ni.com/public.nsf/allkb/63AFE9F8DB0F7F5586257811006E7E51
(7,051 Views)
Thank you for your reply.
>(1)
Oh, I get it.
I was looking for a different method, but it seems to be impossible to use it like RT and FPGA.
>(2)
I get it.
>(3)
Yes.
It is necessary for me to measure the analog voltage of 10MS of the line sensor CCD. As for the clock, a synchronization signal of 10MHz is input into DAQ by CCD.
I wanted to handle it in FPGA of cRIO, but there are not modules more than 1MS.
It is possible if I make a custom module of cRIO, but a my customer does not seem to have the budget.
Thanks!
(7,002 Views)
Thank you for your reply,
I checked DAQ of the USB.
I did not know Multiple Record Acquisitiont. It means that I can measure it continually in two USB DAQ.
I was surprised. I check it a little more.
What I want to realize is as follows.
(a) I perform DAQ for 1 line of the CCD line sensor.
(1ms period, 10MHz clock)
(b) I analyze the data for 1 line which I measured and check whether there is not abnormality (including the range specification)
(c) If there is an abnormality, I record waveform at that time
# When synchronous clock is not usable, it is necessary for DAQ to measure it at 20MHz (twice the clock, software processing).
yh
(6,999 Views)
