VirtualBench
Can I use virtual bench to measure/communicate with other device by I2C etc?
Can I use vitrual bench to measure I2C/SPI/CAN by digital I/O or logic analyzer?
And is it possible using digital I/O to communicate with other device by I2C etc?
Jimmy
(8,107 Views)
You might be able to get it to work (not sure how fast the DIO on the Virtual Bench can go), but for I2C, I would recommend using something that is actually meant for it, like the USB-8451 or USB-8452.
(8,100 Views)
Jimmy
We are planning on adding SPI/I2C protocol decode on the Logic Analyzer and SPI/I2C mastering on the GPIO in a future release.  For now those are not available, but you may be able to decode the data in LabVIEW and master the bus with static GPIO.  Both of those options aren't very ideal, though, and it may not even be possible.  The other option (like was mentioned) was to try out one of the 845x devices that do mastering natively.
Zach Hindes
NI R&D
(8,084 Views)
Thanks guy,
Do you means the function will release in software upgrade?Or new hardware version of VirtualBench?
Actually VirtualBench is very attractive if it can decode and mastering.
If this function will include in software upgrade, I will buy one in recent day.
Jimmy
(8,057 Views)
@JimmyChung wrote:
Thanks guy,
Jimmy
It would be available in a free software upgrade.
Zach Hindes
NI R&D
(8,042 Views)
The update Zach mentioned is out! Details here:
https://forums.ni.com/t5/VirtualBench/Announcing-free-firmware-update-version-1-1-adds-SPI-and-I2C/t...
William Earle
(7,490 Views)
