VirtualBench
Constant current lower limit
The lowest limit in the constant current mode of the power supply seems to be 30mA and 10mA for the different channels. The spec sheet defines the limit of accuracy as 10mA and 4mA.  Why the discrepancy?
(4,675 Views)
Hi sadeghi,
Before I can really dig into this issue, I would have to know what exact power supply you are using. We have many different power supply products. Which one are you using?
Nolan H.
(4,618 Views)
Hi
it's vb8012
seems fine after connecting to the instrument
the problem was only in the demo mode
thanks
(4,609 Views)
Beginning with VirtualBench 15.1, the demo mode simulates a VB-8034, not a VB-8012. The demo should therefore match the 8034's specs. You can see the model being simulated if you look at the File >> About dialog.
(4,595 Views)
