VirtualBench
Data Acquisition in Virtualbench
I am measuring motor current using NI Virtualbench and current-probe. When I export data to CSV spreadsheet, I see two columns of data with header 'min' and 'max'.
How do I get the actual data? By adding min and max? A photo is attached for reference.
(4,323 Views)
Accepted by topic author shifat046
Hi!
Based on your description of the (min, max) data, the VirtualBench scope is likely in Peak Detect mode. You can either change modes to Sample, which captures a single value, or average each min-max pair.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,315 Views)
THANK YOU
(4,231 Views)
