VirtualBench
Function Generator signal types - chirp/white noise
Having demonstrated the VirtualBench to some of my colleagues, I'm getting feedback that engineers would like to be able to add white noise to the output from the the signal generator, and/or add the option of a chirp output signal type.
Can I propose this as a feature to be considered for inclusion in an upcoming version please?
Martin
(7,701 Views)
It's not featured in the VirtualBench Application, but you are able to output custom waveforms (such as a chirp) using the VirtualBench API.
In LabVIEW this is done with FGEN Configure Arbitrary Waveform.vi, as demonstrated by this example. In the C API you would use the niVB_FGEN_ConfigureArbitraryWaveform function.
(7,696 Views)
That's geat Brandon, thanks for letting me know.
Do you think it might be added to the VirtualBench Application in the future?
(7,677 Views)
I filed a feature request on your behalf, CAR 515331.
Zach Hindes
NI R&D
(7,667 Views)
Any follow ups on white noise generation directly from the VirtualBench software without third-party tools?
(4,389 Views)
