VirtualBench
How to log data from the DMM inserted in the VirtualBench?
Hi all
I am using the DMM inserted in VirtualBench-8012 and trying to log the data with respect to time. However, I haven't found how to log the data from the DMM (the screenshot can only record the data from DMM at a certian time...). If anyone knows, please let me know. Thanks!
(6,703 Views)
Continuous logging is not available in the VirtualBench Application, but you can implement it using the VirtualBench LabVIEW or C APIs.
(6,689 Views)
Hi there,
What is the sampling rate of DMM in virtualBench. If I connect it to the labview?
thanks
(5,572 Views)
Hi ku22,
According to the VB-8012 Spec Sheet, the DMM sampling rate is set at 5 S/s.
(5,548 Views)
