VirtualBench
The VirtualBench driver and Labview are not installed successfully.
We purchased the NI VirtualBench a few months ago, and wanted to connect the hardware to the LabView.
As for the Labview software, we have a problem about Hardware Support for Labview. We couldn't find the required files for that.
During the installation of VirtualBench driver, it said "There are no notifications for your products.", so it failed to install the driver.
Please contact us as soon as possible. Thank you so much.
(6,546 Views)
What version of LabVIEW?  What version of the VirtualBench software are you trying to install?
Typically with the "There are no notifications" just means that you are trying to install the latest and/or there are no patches.  You should be able to click Next to continue with the installation.
(6,540 Views)
Thanks for the reply.
I was trying to install the Labview 2013 and Virtualbench driver 1.1.1.
If it was wrong, what version of software should I install?
(6,533 Views)
crossrulz is correct a message saying "There are no notifications for your products." does not mean there was a problem installing the driver, but that there were no further updates to it.
It's possible that you chose an installer that did not include LagVIEW support, but just the application. There are three installers, and you want the download and install the Driver installer:
Driver -- includes LabVIEW API, C API, desktop application, documentation
http://www.ni.com/download/ni-virtualbench-driver-1.1.1/5116/en/
Runtime -- includes just the runtime files for deployed automation support
http://www.ni.com/download/ni-virtualbench-runtime-1.1.1/5117/en/
Application -- includes desktop application and documentation
http://www.ni.com/download/ni-virtualbench-application-1.1.1/5118/en/
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,523 Views)
