VirtualBench
Using VirtualBench (NI VB-8012) SPI engine through C - API
Can I use digital IO lines for SPI transfers?
Someone please point me to the documentation for the C API functions with this information.
I looked in 'VirtualBench C Reference Help' documentation and 'VirtualBench ANSI C Examples' provided with drivers but could not find the details. Only reference for info on ALL available functions in the API is the header file (VirtualBench.h).
(4,230 Views)
In most cases, C API follows the same pattern and functions as its LabVIEW counterpart. Here are a couple of LabVIEW examples for SPI interactions. Try looking for equivalent C functions to the functions used in these examples.
Master SPI with DIO
SPI Decoding for VirtualBench
Matthew C.
NI | AE
(4,196 Views)
Hi Matthew,
Thank you for the links.
(4,194 Views)
