VirtualBench
Virtual Bench VI with other hardware?
Hey, hope someone can help me...
i tryed to use a VI from NI:
https://forums.ni.com/t5/Example-Code/NI-VirtualBench-Erfassen-analoger-und-digitaler-Signale-mit-de...
but i have´nt the required hardware. i thought i can use it with my NI scb68a.
Question one, is this possible?
And Question two: can you tell my how i can "freeze" or pause continously measured real time signals, produced with a Mems sensor (...to do a fft-analysis) ?
i tried to create my own oszi and i have the idea to do it with a trigger, but always when pushing the trigger, my signal gets lost!?!?!? o.O
(3,926 Views)
Accepted by topic author Gregory88
1. The SCB-68A is not a device.  It is just a connector box for using discrete wires.
2. The VirtualBench VIs are only for the VirtualBench.  What you are asking is like trying to use a serial port driver to run a monitor.
3.  If you have a SCB-68A, it is very likely you have a DAQ from NI.  This means you should be using DAQmx.  And those drivers will likely answer your last question since you read snapshots during the acquisition.
(3,912 Views)
