VirtualBench
VirtualBench MSO measurement from labVIEW
Hi!
I have just started playing around with the VB and really like the windows application and how fast it is to setup the basic functions.
However the intended use in our company will be to automate it using labVIEW, and it seems that  there are some functions that exist in the windows application that are not yet implemented in the labVIEW drivers.
What I'm currently missing in the labVIEW driver is the ability to read measurements from the MSO. The functionality seeems to be ther in the windows application, so I'm wondering if I'm missing something in the driver or if this functionality is not yet implemented? If so, is there any ETA when this will be made availiable?
BR,
Christian
(5,157 Views)
Allard wrote:
What I'm currently missing in the LabVIEW driver is the ability to read measurements from the MSO. The functionality seems to be there in the windows application, so I'm wondering if I'm missing something in the driver or if this functionality is not yet implemented?
The VirtualBench API does not have scope measurements because LabVIEW has a waveform measurements palette [1] [2]. For example, a peak-to-peak measurement can be made using Amplitude and Levels.vi. LabVIEW also ships with examples for using this palette [3].
[1] Palette location
http://forums.ni.com/t5/media/gallerypage/user-id/95072/image-id/168471iA7CD37973A8B0ED2
[2] Waveform Measurements VIs help
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/signal-processing/wavefor...
[3] Waveform Measurements Example VIs
<labview root>\examples\Signal Processing\Waveform Measurements
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,145 Views)
