VirtualBench
VituralBench iPad wifi connectivity issues
I am having issues connect to a VirtualBench over WIFI with an iPad Pro. The VirtualBench is MN: NI VB-8012, PN: 154321E-01L.
The iPad will detect the VirtualBench as wifi network but cannot connect. I did verify that the VirtualBench is setup as an access point. I did attempt to connect with another iPad and it also failed.
The iPad will connect other VirtualBenchs.
Everything seems to function fine through the USB port.
Any help would be appreciated.
Message 1 of 1
(3,273 Views)
