VirtualBench
Windows 7 Freeze with VirtualBench
I am running Windows 7 in a Virtualbox (Oracle), under Linux. (Ubuntu).
We use in the company Windows 7 Enterprise edition.
Installed Virtualbench application - off-line edition.
After enabling in the virtualbox the USB devices the NI Virtualbench is connected to, the application works. It shows the oscilloscope noise or test signal, voltage from the multimeter.
As long as I do not press any menue or other function with the mouse it continues to work.
Clicked on <Files><About> and 5 seconds later the Windows 7 was "DEAD". It was not 100% dead, the mouse still moved. But any action, either by a mousclick or by pressing "Alt"-"Tab" had no effect. Pulling the USB cable did not work either.
Interesting was, that in the Gnome System Monitor, 1 CPU (of my 4), ran also 100% utilization. Seems it was the virtualbox loading the CPU.
I did not spend much more time to investigate, since it is quite timeconsuming to repower the machine.
What can be done to fix this issue?
(5,406 Views)
Accepted by topic author jhorvat
There are two options:
  1. Try using WiFi instead of USB.
    To configure the WiFi settings, you can either use the VirtualBench application or MAX. Since the VirtualBench application hangs in your VM, you can either try to use MAX or use a native Windows OS and the VirtualBench application.
  2. Use a native Windows OS.
    USB support for NI products on VMs is very dependent on the host OS, the VM software, and the NI device. Every combination yields different results, while networked devices are more reliable.
Are NI Products Supported on Virtual Machines (VMs)?
http://digital.ni.com/public.nsf/allkb/31B0985265CA167886257831003F5536
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,379 Views)
