VirtualBench
x,y curve plotting/scope mode with VIRTUAL BENCH
Is there a way to plot X,Y curves or CH1 VS CH2 with VIRTUAL BENCH SCOPE application software or are there any LabVIEW example or third party VI's that demostrate this ???
(5,573 Views)
It looks like this can not be perfromed in the latest version of VirtualBench Software but I can modify the LabVIEW VirtualBench IV Curve (PWS and DMM) VI by replacing them PWS and DMM vis  with the VirtualBench LabVIEW MSO VI's.
(5,562 Views)
No, the VirtualBench application does not support an XY graph. I'm curious, though, what do you do with that information?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,557 Views)
In Hydr Servo Valve Test it is common to plot in x,y mode for Current versus Pressure, Dispacement etc......
(5,551 Views)
