http://digital.ni.com/public.nsf/allkb/09794AF61D4CE35286256DBA0075150A
Currently, we cannot update .icd file through LabVIEW using IMAQ. The only way to do so is saving new values in MAX.
However, IMAQdx has this functionality. It would be very convenient if we can update .icd files using IMAQ as well.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9u4SAC&l=en-US
