I'm working on a school project which is a resistor sorter. I'm tried to use the color segmentation from the Vision assistant but I couldn't get a match because the clasifier I used was based on a resistor and can't be used if I changed the resistor. I've also tried this VI but I can't determine the color code via the RGB profil .
1/ How can I make a clasifier file to include all possible colors?
2/ How can I modifie my VI to get the RGB values of only the bars?
