Currently IMAQ Is Vision Info Present / Remove Vision Info 2 VIs only accept all or single specific type of Vision Info.
It would be useful to check for and remove multiple types of Vision Info in an image at once (e.g. all grayscale template info) and these VIs actually already support this, but for some reason the functionality is not exposed:
Please consider this improvement while fixing a related bug.
