3 |
Linescan smart cameras |
Speed and sensitivity critical. 48kHz line rate with excellent sensitivity from blue through NIR. Blue is needed for online fluorescent applications, white light is for most applications, and NIR for inspections that need to avoid the influence of graphics. |
