 4  |
 VBAI  |
 Timing Step  |
 A very commonly used custom VI for run-time: Timing step which provides bot the current time and the time lapsed from the last time this exact step was executed.  |
Provides a benchmarking utility which could be used in runtime.
There are already lots of benchmarking tools in VBAI and it's very easy to accomplish this specific task with a Run LabVIEW VI, so I don't think we will have a dedicated step for this at this time.
Thanks for the idea and let me know if you have trouble getting some of the other ways of benchmarking to work for you.
Brad
