2 |
VBAI |
VBAI step for programmatic control for grayscale operator (e.g. Subtract a gray level based on the results of a previous step histogram). – OR – Update the Vision Assistant tools to use inspection variables for all their set points. |
Basic functionality missing from VBAI; available on the lowest cost smart cameras from most major competitors. |
The ability to use previous measurements is now available in Vision Builder AI2015 from the Vision Assistant Operator, Color Operator, and Geometry Rotation steps. Thanks for the suggestion.
