Volume License Manager and Automated Software Installation
How do I get a report of Home Licences assigned In VLM3.1?
We are currently running VLM V3.1, and I have recently taken over the licence management role.  I know that we have a number of home licences issued, but I can't see how I can check which PC's have the home licence issued, and the details of the associated home PC/laptop.  Can anyone tell me how I can find this info please?
(5,801 Views)
Hi Tigerdurham,
If you open up VLM, on the bottom left you have multiple tabs. If you Select the 'Licenses' tab you should be able to see al the licences you have. Expanding this option will provide you details as to which groups/computers have access to this licence.
I hope this helps,
Ashley
Ashley Nunn | MEng (Hons) | CLA | CTD
Senior Technical Support Engineer, NI
(5,778 Views)
HI - yes, that let's me see the licences and allocations.  However I am trying to see which ones of the Developer Suite's have home licences taken out.  I can't see where I can find that out.  It doesn't appear in the window you have referred me to.
(5,762 Views)
Thank you for your question.  You can either disconnect a USER or COMPUTER license.  You can look at either the User or Computer tab, then find a column called Home License Expiration.  If you see a date filled in then this end user has disconnected from the VLM Server using a home license.
At or near the expiration date, the end user will need to contact their administrator to either reconnect to the VLM Server or have a new Home License issued.
(5,720 Views)
