Volume License Manager and Automated Software Installation
Is it possible to create an installer with multiple versions of LabVIEW?
I have been presented with a request to support multiple LabVIEW versions in a common installer.  Specifically, we are currently standardized on LabVIEW 2014 for most of our active program development. However, due to required features and functionality, we will need to support LabVIEW FPGA 2016 and its associated drivers.
(4,950 Views)
Hi DEPutman,
I believe that it is possible. In VLM when selecting the installation media to build, have you tried selecting a folder with both installers in it? Also, is there a reason that you can't build two installers, one for each respective LabVIEW version?
Mark M.
Applications Engineering
(4,880 Views)
Mark,
Thank you for the reply.  I will give your suggestion a try.  I have the installers build and distributed for the individual versions - that is my normal process.  The motivation behind my request is that my client has asked for a single installer to load everything that he needs.
(4,868 Views)
