Volume License Manager and Automated Software Installation
Starting LabVIEW using a specific user / license
I'm trying to set up a Jenkins Build server but I'm facing a licensing problem. LabVIEW can not find a valid license when started by Jenkins.
Neither a license directly from the server nor a disconnected license we created especially to try.
I have tried to start the Jenkins service with my user credentials, but this does not improve the situation.
Is there a possiblity to start LabVIEW within a specific user context? Sth like LabVIEW.exe -user:JohnDoe to enable correct license retrieval?
Cheers
Oli
(7,006 Views)
Hi Oli_Wachno,
maybe this presentation or the following Getting Started will help you with your Jenkins issue.
Community: NI Week Continuous Integration with Jenkins and LabVIEW Presentation - National Instrumen...
Community: LabVIEW & Jenkins Batch File Build Process - Getting Started - National Instruments https...
Best wishes
Tenshinhan
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(6,992 Views)
Hi Tenshinhan,
thanks for the reply.
I'm already active in the threads, you've referred to. They led me into this particular forum
Oli
(6,989 Views)
So to answer your question, it is not possible to change the license by a specific LabVIEW Call.
The licenses are stored in the license manager or an Volume license server.
There they can be activated.
Normally you will use a computer based license if several users are using LabVIEW on the same machine.
(6,987 Views)
