Volume License Manager and Automated Software Installation
change info displayed on splash screen Help--> About
When I open NI Multisim and click on Help-->About, the splash screen displays the following information in the upper left hand corner of the splash screen:
test
Benjamin Franklin Institute
Serial#
How/where do I change the word "test" so that it doesn't appear on all the classroom PCs?  Where is the source of the identifying information that appers on the splash screen?
Thanks.
(7,259 Views)
In this case “test” is making reference to the Register Owner. This information is requested during the installation process. You will be able to modify this information by modifying a key in the Windows Registry.  Please refer to the link below for more information.
http://digital.ni.com/public.nsf/allkb/0385A6FBAADE844286256DDB0066FCE8?OpenDocument
MCOTO
(7,237 Views)
Thank you.  The path to the String value that needed changingd on Windows 7x64 was HKLM\Software\Wow6432Node\National Instruments\Circuit Design Suite\13.0\Common
(7,215 Views)
