Volume License Manager and Automated Software Installation
is it possible to run VLM and lmtools on the same machine
hi together ... is it possible to run VLM and lmtools on the same machine without any problems?
the running system will be Windows Server 2008 R2 x64! maybe we will install the license server on the virtual server.
(7,110 Views)
Hi SvenNittmann,
in general, it should be possible to run both tools (VLM and lmtools for FlexNet) on the same machine. But I wouldn't recommend you this way, because NI VLM is also build on top of FlexNet and sometimes you will receive ugly problems with the installation of both tools on the same PC. It is possible to use VLM in a virtual machine without any problems or restrictions. NI provides information about the usage of VLM in a virtual machine, like you can see here:
Volume License Manager on a Virtual Machine - National Instruments
http://digital.ni.com/public.nsf/allkb/5730FDDC97F9157E8625755F00749CFF?OpenDocument
I also use VLM in a virtual machine and I could recommend you the same solution.
Regards, Stephan
(7,098 Views)
thanks alot for your feedback
(7,091 Views)
