Washington Community Group
Is LabVIEW designed for complex applications?
This is a question we get all the time. Hundreds of companies in the Northwest have used LabVIEW for small, simple applications and wonder if it can be effectively used for larger, more complex applications. The answer? Yes- but only if you set up a process to use it correctly. Just as with any other programming language, solving complex problems requires sophisticated tools, proper training, and careful planning.
Eli Kerry posted a great article about the elements of a well-architected program, including the tools needed, and how LabVIEW works with those tools. If you are considering a large project and are wondering about LabVIEW as a fit for that application, read this article. If you need advice in getting started on the tools mentioned in this article, contact one of us locally. We can get you started on the right path to success.
Best Practices for Software Development
Message 1 of 1
(10,346 Views)
