Question 1) What is the result in Array after the following code has executed ?
Answer
 1-D array of {1, 4, 3, 2, 1, 0, 8, 6, 2}
Question 2) Mention all the different ways of creating an array in LabVIEW ?
Answer
an array of that datatype.
an element thereby forming an array outside the loop.) The array is equal in size to the number of iterations executed by the for loop and contains the output values of the for loop.
Question 3) What is the purpose(s) of using the Wait function in while loop ?
Answer
Rules & Guidelines
Q: please include in your coming webinars an explanation and examples for MyDAQ
1 4 3 2 1 0 8 6 2
3.to introuduce delay
Answer 1) 1 4 3 2 1 0 8 6 2
Answer 2) Auto indexing on Loops , Initializing Arrays, Using Array Constants, Inserting Elements into Empty Arrays, Building Arrays
Answer 3) Limit loop execution time (That prevents unnecessary iterations and give the processor to run other tasks). Also sometimes synchronize the loop with a timer.
Answer 1) Array with following elements [1,4,3,2,1,0,8,6,2]
Answer 2)
Answer 3) In order to reduce the processing time (or processing load) consumed by the while loop.
Ajay
1. result in array after the code has been executed : 1 4 3 2 1 0 8 6 2
2. An array can be created in many ways
a. using the "Initialize array " function
b. indexing an element at the end of a for loop.
c. indexing an element at the end of a while loop by enabling the indexing option.
3. wait function in the while loop is added to free up the processor. it lets the processor to do other tasks for the time mentioned in the wait function. if it is not use , the processor shall never leave this particular loop and parallel processing can not be done.
Answere for the Questions:
1.{1,4,3,2,1,0,8,6,2}
2. - Enable auto - ndexing in a for or while loop
- Use Build array function
- Use initialize array function and use Replace array element to modify the elements
3. Wait function is used to free the processor time for doing some other activity
1Ans:[0,1,8,6,2]
2Ans:by usibg for loop we can create the arrays,
by using build array function also we can create arrays
directly placing array control on front pannel
3Ans:giving the time to the processor to execute other tasks
Q1) The resulting array has the element of 0 in every index .
Q2) The array can be created by creating a control from the front panel
By the functions
cluster to array, Matrix to array, Initialize array, build array, and creating an indicator for number of values
Q3) by using wait function
(1) we can get the values one by one with the time specified by us (during data acquisition in the loop)
(2) To introduce a time difference between present and next iteration of the loop
Thank you for your webinar...
Answers for webcast on 8 th may 2013.
1. 143210862
2.array can be obtain using following methods.
i.for loop auto indexing.
ii.using initialize array function
iii. drag const array function on block diagram.
3.
i. to control loop frequency
ii. provide the processor with time to complete other tasks.
Q.1 Output Array : 1 3 2 1 0 8 6 2
Q.2 Creating array , Build array, initialize array, String to Array, Matrix to array, Index array, Insert into array,
Q.3 To wait for specified time duration in seconds.Wire Zero to input of wait to current thread to yield control of the CPU.
Answer-1:0
Answer-2: 1.Through Controls >> Modern>>Array, Matrix, & Cluster and drag the Array shell onto the front panel.
2.On the Functions >> Programming>>Array>>Array Constant onto the block diagram.
Answer-3: To understanding the programming flow and for synchronization with external interfacing
Answer 1) The program inserts the subarray [4,3,2,1] after the first elementr of the array [1,8,6,2] as the index is 1. ( [4,3,2,1 ] subarray corresponds to i=1,i=2,i=3,i=4 i.e., the iteration values of the for loop for N=5
2) Using loops and using Build array function in the array tool palatte, or convertfrom cluster to array using function in the tool palatte.
3) It is used to delay the iteration by a specific time i.e., in timing related applications or building timer VI's etc.
question 1 : 1 - 4 - 3 - 2 - 1 - 0 - 8 - 6 - 2
question 2 : we can create array by :
1/ adding an array shell to the front panel and dragging a data object or element into the array shell. (for control and indicator)
2/ adding an array shell to the block diagram and dragging a constant data into the array shell. (for constant)
this is for 1 dimension array. To add dimension to the array, we can select add diension from the shortcut menu or resize the index display.
question 3 : we use a wait function in while loop to control the iteration frequency or timing. even if we not need that the execution occur at certain frequency, we need to provide the processor with time to complete other tasks.
Question 1:
The Result of the Array will be [1 4 3 2 1 0 8 6 2]
# Since the Insert into Array is at Index 1, so all the new values will be inserted at that index, while shifting the rest of the array downwards.
# The increment "i" starts with value = 0 till 4, after finishing the 5 iterations of the For loop.
# The Feedback node acts as the Shift Register; reinserting the new array in the input of the "Insert into array"
Question 2:
# Offline Array Creation
1. Creating an array Constant and dragging any datatype inside (Front Panel & Block Diagram).
2. In the Block Diagram, Create an Array by: Right Click then Create (Constant, Control or Indicator) on any of the Array Palette functions' inputs or Other Functions accepting or releasing an array.
# Programatically
1. Using the Build Array Function with any Data Type.
2. Using a For Loop and Enable Indexing on Output for any data type
3. Using a Math-Script or Matlab Script and Writing down a Variable in the Array text Format : X = [1 2 3; 4 5 6] (2D Array)
4. Using any conversions to array (Cluster of specific data type to Array), (Number to Boolean Array), ...
Question 3:
1. The main role of the Wait function is to give the processor the chance to complete other tasks on the Operating System.
2. It gives the code a kind of synchronization, thus the loop is expected to finish one iteration at a specific periodic time.
1) array size is 1*5 and all the array element is zeros.
2)By placing the array controls in the front panel and perform different array operations on the block diagram like build array and insert into array.
3)To reduce the cpu burden.
Answer 1: The Result in Array after the code was executed is a one dimensional Array with output as
[1,4,3,2,1,0,8,6,2]
Answer 2: Different ways of creating array in LabVIEW are
1. Build Array
2. Custom Array
3. Array Functions
Answer 3: The purpose is that when the wait function is attached to a while loop it extends the total time taken to execute the loop. This total time includes the time taken to execute the code and the wait function time. The Wait function and the code executes simultaneously together.
Q1) [1 4 3 2 1 0 8 6 2]
Q2) Initialize array, Build array, loop tunnel with indexing enabled,
Q3) add delay to loop excution time (not recommended since it prevents user interaction during the wait period)
1. 1
4
3
2
1
0
8
6
2
2.
Functions Palette → All-Functions → Array → Array
Constant
• Right-Click on the box → Arith/Compare → Numeric →
Num Const → Drag into the empty array
3.delay for a particular period of a time
1.13210862 will be the result in output array
2.we can create an array in control panel and block diagram
IN FRONT PANEL:
in controls pallette(right click on frontpanel to get control panel) select : modern >> Array, Matrix & Cluster >> Array.drag and drop it on Front panel, now select control or indicator of any data type or data structures (numeric, boolean, string, array, cluster) and drop it into the array to create array of control or indicator.
IN BLOCK DIAGRAM:
1. funtion pallette >> programming >> array >>Initialize Array.
2. funtion pallette >> programming >> array >>Build Array.
3. In programming using a while or forloop by enabling indexing technique we can create array of different dimensions.
using any above 3 different ways we can create array.
3. when the While loop will finishes executing one iteration, it immediately starts executing the next iterations
Q1)it will be the array [1 4 3 2 1 0 8 6]
Q2)Depending on the type of array different ways can be followed:
A)One-Dimension Array.
 1) input or output array : Controls Palette → All-Controls → Array & Cluster → Array
2) constant array: Functions Palette → All-Functions → Array → Array
Constant
B) Multi-Dimensional Array.
1)Creating a matrix (same ways as one-dimensional array)
Q3)
1)It acts like a sampling period for the while loop
2) It is used as timing control for a While Loop to prevent LabVIEW from using too much of the processor.
Answer 1)  Result in Array after the given code has executed:- 186211
Answer 2) On Back panel
a) Goto Functions click on Programming click on Array and select Array constant and drop it on block diagram then select any kind of data( int, float etc...) by dropping any controllers in array constant
                               Functions - Programming - Array - Array constant
On Front panel
b) Goto Controls click on Classic click on Array,Matrix... and select Array constant and drop it on Front panel then select any kind of data(int,float etc...) by dropping any controllers in array constant
                    Controls - Classic - Array,Matrix... - Array constant
Answer 3) Without using Wait Function in While loop the recursion is going to be done with maximum capability or max speed of the processor(depends on the machine cycle) which gives more pressure on processor and That much speed is not necessary for common use so we use wait function to decrease speed of loop and increasing performance of processor
To interface hardware modules like(LCD display,Microcontrollers,Ultrasonic sensor) wait is used. Since the speed of hardware modules like(LCD display,Microcontrollers,Ultrasonic sensor) is very slow comparing to the processors that we use in PC, by using WAIT function we can match up the speed and make communication with them
Finally I just want to say thanks a lot for conducting such programs to educate students like me and providing such a big platform to interact with each other
- The result will be
[1,4,3,2,1,0,8,6,2]
-Creating arrays:
1) control arays:
A-On the front panel, from the aray toolbox, place an array on the front panel; then define the type by dragging a [numeric/text/boolean/etc]-control inside the array
B-on the block digram with a relevant function, click the input node of the function and right click, choose create > control [works only if the input type is determined either due to the function's specifications or by wiring another terminals that consequently determines the data type and array dimension of the node under consideration]
2) constant arrays
Same as above but with the (A) option only applicable in the block diagram rather than the front panel and by dragging a constant to the array in order to define the data type
For option (B), choose create>constant
3)Indicator array
A- from the front panel as mentioned before but by dragging an indicator to define the data type
B- from the black diagram by clicking the relevant function block's output terminal and create>indicator
C- by rightclicking on any datawire and create>indicator
Note: option (C) if applied to create a control or a constant array will create an unwired array of the same type and dimenstion of the data in the selected wire
-The wait function allows to freeze the loop for a some time between iterations if a single iteration is finished in less than this specified time to allow for some processing time for other pending OS and/or other applications processes
Answer: 1D Array = 143210862
Answer:- 1.By Using "For Loop/While Loop" with Enable Indexing by generating Random Number as well as Number of Loop Iterations.
Answer:-
Without a delay, the loop rate can be in the millions of iterations per second range depending on what is inside it. So that means that your CPU has about 1/1000th as much work to do and can go off and tend to other tasks. If your loop was already taking several ms, then the 1ms delay is likely in parallel and it won't affect the loop speed noticeably. So placing the delay in the loop can drop your CPU usage noticably and allow time for the OS to do other work like send messages that your application may be waiting for, etc.
2. By Using "Build Array" Function
3. By Using "Initialized Array" Function
4. By Using "Matrix to Array Function"
5. By Using "Cluster to Array " Function
Answer:-
