Western NY LabVIEW User Group
MSO/DPO Tek 4034 USB Communication
I am using Tek MSO/DPO4034 with USB Communciation and Labview 8.2.1 Instrument Driver.
I am getting an error with I talk to scope more than twice. I have 10 separate tests. If I run them individually, I am ok.
If I run them as together in sequence.  I get this failure Status: 0xBFFF0015 (VI_ERROR_TMO) most of the time. I will pass once in a while.
I use the same setup each scope use. I change the meaurement type & timebase value.
> VISA Write ("USB0::0x0699::0x0401::C021220::INSTR", "VERB OFF;")Process ID: 0x00000FB0         Thread ID: 0x00000FDCStart Time: 10:48:24.751       Call Duration 00:00:02.016Status: 0xBFFF0015 (VI_ERROR_TMO)
I tried putting delay time of .2 to .5 sec between scope setup. No success.
Capture file is from NI Spy.
Any help would be appreciated.
Greg
Greg
Message 1 of 1
(7,015 Views)
