Western PA LabVIEW Users
Converting data for use with Analog I/O on R-Series Intelligent DAQ
Description:
Two VIs for converting between analog voltages and ADC/DAC "counts". For use with ADC and DAC chips which provide 16 bit
Details:
Some customers have asked how we can send voltage data to an analog output or read voltage data from an analog input of an R-Series intelligent DAQ board. The answer is to convert.
We know that the A/D and D/A use a 16-bit converter, and provide a voltage range of +/- 10V. The result is that each "count" is +10V + |-10|V / 2^16 volts per count. I have written two VIs to help convert to and from ADC and DAC counts.
ADC Counts to Volts
Volts to DAC Counts
Message 1 of 1
(8,516 Views)
