Western PA LabVIEW Users
Flow Measurement Solutions
Good Morning.
Does anyone have any experience with flow measurement systems?  Right now we are using Transonic clamp-on flow probes and their associated meters and we are considering a change of pace.
We are operating a pulsatile system with saline at 37C, 3/4" and 5/8" ID tubing, and deal with flows from lets say -5 to 20 L/min.
The biggest issue that we are dealing with is the fact that each of our 36 flow probes would need its own flow meter to read and re-transmit its signal.  So instead of having that massive bank of meters, we have 2 that connect to 18 probes each through a multiplexer.  What would be much better would be to have 36 outputs that I could feed to a nice SCXI daq board.
The only other catch is that these devices need to be able to be calibrated against an NIST on a regular basis, hopefully without interrupting the test to much.
So I ask you for your input and advice.  We are pretty open minded to any solutions that you can offer.
thanks!
(12,581 Views)
We use various MFC and flow meters but not in a pulsed application.  You could look for 4-20mA sensors that would work for a pulsed application.  I'm using rota-meters which have a very slow output.  Have you tried using a pressure transducer instead of a flow meter???
(10,494 Views)
We do simulations of human respiration and have to control multiple gas flow paths using MFCs.
(10,494 Views)
We measure flow rate with the use use on an encoder.
(10,494 Views)
Thanks for the insight everyone.
I am meeting with Kobold today regarding their Magneto-Inductive Flowmeters. Turns out another co-worker is working on a project involving flow, so we are gonna see what they have to offer and see if it meets out needs.
I might be running into some power and signal issues... 24VDV input and the output is in current.. so its one of those, here is the tool you need, but I forsee alot of additional hardware.  anyone know if there is an SCXI module for current in? or am I gonna be buying alot of extra hardware ya think?
I am new to this stuff, so thanks for any insight and assistance
(10,494 Views)
Where do you work bmyerspgh?
(10,494 Views)
