Wireless Sensor Networks
3202 WSN node configuration as router
Hi all,
I recently started using NI WSN. I managed to acquire signals by the WSN Gateway from multiple end nodes.
I've read on ni.com that in order to achieve more than 8 end nodes we should use some nodes as routers.
Now I'm wondering how to exactly do the configuration of the WSN node to make it work as a router not as an end node.
I'll really appreciate if anyone could help.
Thank you in advance.
Gevorg
(6,714 Views)
Go in MAX or in the web interface via your browser, select the node you want to change into a router and just click "change network mode".
Have a nice day
Matt
(6,710 Views)
More info about WSN setup can be found here:
http://www.ni.com/white-paper/11211/en
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(6,701 Views)
Thank you about this.
Unfortunately yesterday I faced another issue. Does anyone know is NI-WSN 1.3 driver software supported by Real-time 12 ? Is there any updated version for Real-time 12?
Thank you
(6,694 Views)
The NI-WSN driver for LabVIEW 2012 should be released soon. For now, you can use NI-WSN 1.3 with LabVIEW 2011.
Zach P.
(6,690 Views)
Thank you Zach P.
Gevorg
(6,685 Views)
