Wireless Sensor Networks
36 wsn-3202
Hello, Dear NI Engineers! There is a task to build wsn net with 9791gtw and 36 x 3202 modules on a COMPACT territory ~ 70x70meters, is it possible? (All the documents are read, please don't refer) Problem is that all modules can "see" radio-signal of each other on the small territory so it produces interference and there is no possibilities to separate wsn-routers. All modules are distributed equably on a square. Wsn-9791 is on the one side of the square on a 8m height. Has Anybody ideas? Or may be sombody can persuade me that such scheme is improper? Scheme in the attachments. Thanks for any help!
Message 1 of 26
(10,263 Views)
attachment...
Message 2 of 26
(10,260 Views)
Hey Kolan,
We actually a test a similar setup here at NI in a much smaller area.  One of our test cases is to put 36 nodes in a small area only a few meters wide.  This topology works out great.  For this scenario, you will need to have 4 nodes externally powered as routers to accommodate for all the end nodes.
Please let me know how I can help with your deployment.  Can you share any more information about what you are trying to accomplish?
Kevin
WSN/Wireless DAQ Product Support Engineer
Message 3 of 26
(10,255 Views)
Thanks a lot, Your information is very helpful.
I've tried this scheme: 4 router nodes which has signal "Excelent". But only 8-23 nodes works. Perhaps, I need to press the button on each wsn-node after reconfiguration? But I'm waiting more than 5 minutes, and modules are not connecting. I'm using 12 wireless channel (Russia).
I'll retry the experiment tommorow and will ask You again, Kevin. Thanks for reply!
Message 4 of 26
(10,251 Views)
Hey Kolan,
What firmware do you have running on the nodes?  It also may be helpful to try a different wireless channel.  ZigBee Channels 15 and 20 are typically the two channels that least affected by 802.11 traffic.
Keep in mind that if you do change the channel, you will need to hold the connect button down for 5+ seconds on all the nodes to get them searching for a new channel.
Look forward to hearing how it works out.
Kevin
Message 5 of 26
(10,247 Views)
Hello, Kevin!
We've followed Your advices, updated firmware to 1.0.1f0(modules) and gateway firmware was 1.0.1. Now just 1-2 modules is offline, all other work Smiley Happy
Wireless channel changed to 20 and result is greater. All experiments will be continued later after 2 days and I'll will post final result.
Thanks for Your help!
Message 6 of 26
(10,237 Views)
Hey Kolan,
I see you are using an older version of the driver.
NI-WSN 1.1 is currently available here.
Message 7 of 26
(10,235 Views)
Hm... it's strange... I've used old wsn driver because I've seen that new wsn installer doesn't offer variant for LabView 8.6.1 version, but only >=2009 and in readme file was the same information.
But I've did it too long ago. I'll try this driver again and post all results 2 days later!
Thanks a lot, Kevin!
Message 8 of 26
(10,228 Views)
Hello, Kevin!
I have one problem with new wsn driver. When wsn module lost signal we'have got an error of variable reading in old 1.0.0 version. But in new 1.0.1 version variable return last value and doesn't let us know is the module connected or not. I don't know is there this problem in 1.1.0 driver because I've not installed it yet. In LabView 2009 there is a way to get information of modules by gateway requests. In 8.6.1 I've not seen it.
And the second problem is when I've installed 1.1.0 driver, updated wsn gateway and the in MAX I'm about to update modules firmware. But MAX write "Update Pending" and nothing else.
Message 9 of 26
(10,196 Views)
update started Smiley Happy
Message 10 of 26
(10,193 Views)
