Wireless Sensor Networks
Best wireless configuration
I have 2 load cells, encoder pressure gauge, to acquire data from and 24 V solenoid valve to control the flow according to the pressure, I want to do this wireless, pleas what is my best configuration to use, I appreciate your help. Thank you
(7,056 Views)
Accepted by topic author zack65
Hi Zach65,
Do you currently have any wireless equipment?  There are two different options that I think might work for you.   You can use a wireless sleave with a C series module, or you can use a WSN system.   The C series module will allow you get setup and start taking measurement quickly and easily.   However you are limited to one C series module per sleeve.   Also, you want to make sure the room in which the measurements are being taken have access to a strong and stable wireless signal.  The WSN system will allow you take long term data wirelessly and allow you to do some real-time analysis on the data.   I would definately call National Instruments and tell them your setup and system needs.   They will be able to help you build a system that meets your specific application.
Best Regards,
Starla T.
(7,045 Views)
