07-28-2011 06:40 AM
Please how is it possible to change the variable data type of TCO of WSN-3212 from single (32 bit real ~6 digit precision) to array of UInt64 data type.
Blessing
06-17-2012 01:42 PM
What version of LabVIEW and the WSN drivers are you using? This makes a big difference as the capabilities have changed drastically.
Also, why do you you need an array of UInt64's to describe a number that can be described with a single? Are you thinking that you will be able to get more precision? Unfortunately, that will not be possible.
