Wireless Sensor Networks
Flash 9792 with image
I have several 9792 units that I have to configure. This includes loading the NI realtime software and loading some custom software. It is a long process the way I was tought to do this by the person who originally was over the project. We have several of these 9792 gateways and the only difference among them is their configured name and assigned IP address. I wanted to know if I can make an 'image' of sorts of one of the gateways I have already configured and simply flash it to the other gateways as needed. This would save me a lot of time.
(4,953 Views)
You could potentially use the RAD utility but I'm not sure if it only works with cRIOs, so you might want to look into that.
RAD Utility
https://www.ni.com/en/support/documentation/supplemental/12/archive-of-the-real-time-application-dep...
(4,933 Views)
