Wireless Sensor Networks
Get User Messages on the Host PC from WSN Nodes
   I have read the "LabVIEW Wireless Sensor Network (WSN) Pioneer - Under the Hood" and try to transmit user messages from a WSN node to the host.
However, I am stuck at the WSN Get New Messages VI. I am unable to use a "Display Message to User" function or "Unbundle function" to retrieve the messages from WSN Get New Messages VI. Can anyone help me ? I have been stuck here for hours. Thank you very much !
Xinke
(6,855 Views)
Hi xinke,
looking at your code, I believe the issu eis that the output of the Get New Message node is an array of clusters and as such should be indexed as with a normal array before being split up with unbundle. i have attached a VI that shows this to my post.
I hope that this helps!
Liam A.
(6,839 Views)
Thank you for your assistance !
But I am unable to try it out as I encounter a new error "LabVIEW:  Invalid entry in configuration file.".
Can you assist ? Thank you.
(6,831 Views)
Hi xinke,
This seems a rare occurence, the only time of which I can find the problem was solved by opening the project in LabVIEW 2009 before re-opening in LabVIEW 2010. I don't know if this was a solution or simply a symptom.
Let me know if this helps,
Liam A.
(6,823 Views)
Hi Liam,
   I had Labview 2009 installed on my laptop. I have since uninstalled it and installed Labview 2010. I opened a new project in Labview 2010 with a new VI, insert the A01 input from the Analog node and hit "Run" and the error message "LabVIEW:  Invalid entry in configuration file." appears again!
   Can you advise what should I do ? Is there a way I can view the configuration file ? Please advise. thank you.
xinke
(6,748 Views)
Just an update - I have managed to resolve the issue after doing a firmware upgrade.
(6,717 Views)
Could you tell me, where Can I download the firmware to WSN 9791 or WSN 3212, please.
Thank you.
(6,504 Views)
