Wireless Sensor Networks
How do I set the I/O Direction of DIO on WSN to input?
I am trying to record Digital inputs being sent to my wireless sensor node and I can't figure out how to set the node up for input instead of output.
(5,724 Views)
You should be able to use the Node Properties dialog box in the LabVIEW Project Explorer window to change DIO settings.  This can be found by right-clicking on the node in the project and then click Properties.  Hopefully this gets you going in the right direction, but let me know if you're still having some trouble.
(5,714 Views)
