Wireless Sensor Networks
How to connect one port of NI 9792 programmable real-time ethernet gateway with cDAQ 9191 WI-FI Chassis
Hi Everyone,
I have I 9792 Real-time ethernet gateway, it has two ethernet ports. As one of the ethernet port  is used for communication with my NI WSN Nodes and the other one is left free. So i was planning to connect the second port with cDAQ 9191 WI-FI Chassis. Is it possible to do this, IF YES then How?
(6,205 Views)
You cannot do that, since real-time controller doesn't support DAQmx.
(6,200 Views)
Hi
Whilst you cannot use NI DAQmx you could use the web API for the 9191
https://decibel.ni.com/content/docs/DOC-21477
It would allowing to acquire relatively slow data and will require a lot of programming compared to the DAQmx driver but it is a way forward
Mike
(6,178 Views)
