Wireless Sensor Networks
How to make the connections on the outputs of the letter wsn 3202?
Good morning.
I want to report that the letter is already running. But the answer is in the order commanded a little slow. Is there anyway to control this time?
Greetings.
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 11 of 12
(2,890 Views)
The response time is controlled by the update rate of the nodes.  I believe you will find this in the gateway properties, though it may be in the node properties.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
Message 12 of 12
(2,888 Views)
