Wireless Sensor Networks
Micaz mote +MDA1100CB
I need to control the brightness of two LEDs by micaz mote and mda100cb prototype area.I guess Micaz mote does not contain a DAC (Digital to Analog Converter).So,I am wondering if someone knows how to connect the PWM pin of the MDA100CB to an external DAC??
(5,934 Views)
Aziza,
As the components you mentioned are not NI products, you may have better luck getting help with your question from a more general electronics forum.
Good luck with your project!
James K.
(5,918 Views)
